risers
risers
getting ready to do risers on the 454 merc's any hints on how to get the hose's off without cursing all day . and tnt or a chain saw are not tools....(Paul,Jamie and Allen)
I didn't have a problem with my crusaders. I loosened the clamps and took a screwdriver and GENTLY worked it between the hose and elbow to start breaking it loose then grabbed the hose and moved it around until it came off. The merc in my chris craft was even easier to do.
2011 Trojan Rendevous
Solomons Get Together 2011
Ocean City 2012,2013,2015
agree, exhaust hoses were the hardest part of the job. I finally gave up and cut them off and replaced them with new which wasn't the worst idea.
I would do this part 1st in case you run into the same situation.
P.S. - if you wind up replacing, I have Shields 3 1/8" with wire (brand new)
If you have a heat gun, you can remove exhaust hose clamps, and heat up hoses evenly and then apply some lubricant or dishwashing soap while prying around connection. Figure a couple of beers per hose...
No offense, but I wouldn't put GLM risers on my engines...
Osco, Barr or Mercruiser ($) Had great luck with Osco over the years.
Bottom line manifolds and risers,hmc wrote:wHY ?Stripermann2 wrote:No offense, but I wouldn't put GLM risers on my engines...
their castings and fit are subject to early failure and corrosion.
Chinese made...Caveat Emptor
thanks Gettaway but mine are 4" to 3" and getting all Merc. parts . Do like the heat gun ideal Jamie but Hornsby hard cider will have to fill in for the beer....
got the parts, FEDEX Ground dropped them off an hour ago so off to the boat I go tomorrow..
If ya used UPS, you'd probably be done by now...alexander38 wrote:got the parts, FEDEX Ground dropped them off an hour ago so off to the boat I go tomorrow..![]()
Well the boots were dry rotted on the onside and the rises looked about half gone they'll be up and running by 5 tomorrow
