Used, working Garmin 180 GPS wanted
If you have this model Garmin GPS you would like to sell. All I need is the unit itself, mine quit working.
Contact: gruhs2001@yahoo.com
1977 Trojan Tri-cabin
"Seaweed"
Home port East Chicago, In.
"Seaweed"
Garmin 180 wanted
The reason I prefered the 180 is because I can plug it right in. Other Garmin might do the same but I don't know which ones.
Thanks for checking,
Gary
Gary
"Seaweed"
"Seaweed"
reply you question
The old one that I have has the lake michigan chip (or what ever it's called) that I hope will plug into what ever I end up getting... that's another reason to stay with the same model then everything just plugs in and were good to go.
"Seaweed"
"Seaweed"
For what it's worth, that old Garmin uses a g chart/micro g chart which you can't get anymore and there is no support for it. The connections and antenna system are completely different than what Garmin has had out for the past 10 years or more. Plus you can't download newer version of charts.
Look on CL or check with some boating forums for a clean used one or upgrade to another newer model if you can.
Good luck.
Good luck.
I have a Garmin 180 with the local SW US chart.
I also have the manual
Send me a PM if you are interested.
garmin wanted...
Thanks for the info and offers to fix us up with a replacement GPS. We think we have a reasonable deal on a model 182C in progress. If all goes well it will be nice to have a color screen.
Thanks,
Gary
Thanks,
Gary
"Seaweed"
"Seaweed"
