75 flybridge rudder linkage
Try turning the rudders first good chance you will get the props out
DAVIDLOFLAND
Post by DAVIDLOFLAND »
I did. Full each way. Still lacks clearance. Thanks.
Yanmar 6BY3-260's
adm1217
Post by adm1217 »
I was able to replace both of my props with a 10" gear puller without having to remove the rudders...
Adam Nuetzel
I belive the props are lose but won't clear the rudders
DAVIDLOFLAND
Dicsovered I can get clearance by disconnecting both tiller arms, so the rudders can turn a full 90 degrees. But man, is it still close.
Yanmar 6BY3-260's
