NEED INFO
BUCKANEER
NEED INFO
Post by BUCKANEER »
HELLO......... I am new on this and need some info.. I am looking at buying a 1979 32', Flybridge Sedan, T/318's, Gen. What should I be looking for (problems)??? and it needs a AC, where do you put the AC in this?
THANKS!!
BUCKANEER
Welcome aboard. I'm sure some F-32 guys will be along soon to help you out. Great bunch here.
wowzer52
Post by wowzer52 »
Welcome aboard, the worst first, stringers, soft spots in the forward deck and flybridge floor/leaks in the cabin roof, gunky/rusty fuel tanks, thru-hull seacocks/backing plates, and of coarse the engines and trans. The rest is small stuff/easy fixes.
1975 F-32 "SIMPLY BLESSED"
In short, get a survey. If nothing else, any deficiencies found may also serve as a bargaining tool when negotiating the final price, and you'll need it for insurance purposes anyway.
Also what you find is going to depend on the boat's history (obviously). A salt water fish boat and a fresh water family cruiser are going to show different problem areas.
For what it's worth, the A/C in mine is under the forward dinette seat, but that's not an optimal spot because its hard to run ducting back to the salon to keep it cool.
BUCKANEER
Post by BUCKANEER »
THANKS for all the info...
The boat is on the upper Mississippi River and in the same Marina that I am in now..
Just wanted some inside tips on what to look for....
Thanks for the Welcomes... :D
BUCKANEER
rap55
Survey !!!
Post by rap55 »
Survey...Survey...Survey to avoid Mayday...Mayday...Mayday !!! Find a reputable yacht surveyor who has no connection to owner , broker or marina. As bad as we all want our purchase to be a great buy...Haul her out and let a surveyor look at her inside and out. Could be an all day thing but at least you will have a pretty good idea where you stand. Most marinas require insurance and insurance will require a survey. At least that's what I found out. Good Luck and Welcome Aboard !!!
Rick - F-36 / Miss Kitty
g36
Post by g36 »
in my1978 f32. i have a cruisair split system ,there is a evaporator/blower assembly in the stbd side wall in the salon the air return grille is mounted in the center sliding panel. when it is shut it lines up with the unit. the unit is right behind it. the condensor/compressor is mounted between the aft fuel tanks above the fresh water tank under the cockpit floor. there is also a evaporator and blower assy in the v berth. the refrigerent lines are tee'd from the freon lines to the other .
1997 CARVER 405
"the BLACK PEARL"
past fleet
1978 F32 SEDAN CHRYSLER 318's
current fleet
1997 seadoo gts
1997 yamaha wave venture
1985 sunbird 18 ft runabout
1968 coronado sailboat 25 ft
sunfish
14' hobie cat
canoe
8ft portabote
