Who is still using Points & Condenser
good oneprowlersfish wrote:skip the electronic and go to compression ignition
36 trojan tri cabin
http://s1116.photobucket.com/albums/k57 ... ?start=all
WOW, I don't know that I like what I'm reading in some of the posts. I'm not crazy about the SET IT AND FORGET IT mentality. It's not enough to set it and be done with it or that once it's set it will stay tuned all the time, no moving parts etc. This is not a distributor replacement! Proper total advance still relies on a mechanical system. I too used a kit to convert my old distributor but I check my timing AND total advance at the begining of every season in case the advance system starts binding. I don't want my big blues to go boom!! I'm just say'n.
Paul SW Ontario, I think the Sierra is a Pertronics, I may be wrong but here is a link. Send them an e-mail with your engine info and all the numbers you can pull off your distributor, they were very helpful for me. http://www.pertronix.com/contact/default.aspx
Looks like you misread the post. I'm referring to the electronic replacements for the points here. Once its set, you're done. Centrifugal advance and timing are something you look at with every tune up along with rotor and cap. Or am I missing something here?
Bullseye Paul, you still need to look at the stuff under the plate to make sure all is lube and moving.
Don't think I misread anything. What I didn't read before my post was that there is indeed a need to still check timing periodically. Everything leading up to my post can be somewhat misleading for someone who is not familiar with ignition and these conversions, giving them a false sense that once you convert you can forget about timing and simply replace cap and rotor periodically. If I got that impression, I'm sure those without mechanical knowhow did as well.
I agree with everything you've said Paul. My issue is that along with promoting the benefits of the units, one must also caution that they are not a means to forget about timing after the initial setup. Previous posts suggest that quote "Your tune stays the same all of the time". I'm just trying to clarify and caution for the bennefit of those that aren't as savy in this matter.
No points, condensors, coils, distributors, spark plug wires or spark plugs ...
(diesels)
Having some dock work done tomorrow - moving the boat to the neighbors for a day or 2 ... been playing golf.
Gas repower 5k. Oil burner OMG.
Had 3 pilings added to my dock this morning ....rossjo wrote: Having some dock work done tomorrow - moving the boat to the neighbors for a day or 2 ... been playing golf.
Video of 1st, 25' post - pounded 9' into the mud with 800# sledge:
http://rnr-marine.com/Trojan/MOV01483_D ... 1feb18.MP4
The other 2 went on my pier head.
