Hour Meter
fourreins
Post by fourreins »
I guess it would be pretty simple to add one. Would you just add the positive wire to the back of the other key and the negative to the ground???
Thats all you have to do to hook it up
pk
Post by pk »
Mine got two meters. But it is a ten meter...... :roll:
pk
Post by pk »
By the way: When using an hour-meter, it should be mandatory having a logbook. Then you could make a note in the logbook: Hourmeter changed due to ------ at date. I always use a logbook in my aircraft.....
