Can you guess which cylinder is bad?
Allen Sr
Post by Allen Sr »
rossjo wrote:Ugh - you're killing me ... lots of work ... but worth it ... too cold to work on boats right now.
Well then don't come up here on the Ches. Bay. I see where your located, I wish I could get the time to work on mine. Hopefully back to it this weekend!
2011 Trojan Rendevous
Solomons Get Together 2011
Ocean City 2012,2013,2015
Too cold ? The engines are inside just turn on the heat . in the summer use the AC . always good weater in my engine room.
rossjo
Post by rossjo »
Speak for yourself - no heaters here in the South - and my other boats are on trailers ...
Jerry
Post by Jerry »
As long as the sun is out, even if the outside temps are down in the single digits, the inside is workable. The shrink wrap heats it up nicely.
I also run suplemental heat as I am not as young as I once was.
I normally just wear a sweatshirt and am plenty warm.
About the only nice thing about having the engine where they are is in the summer I crank the AC when doing any work on them.
