Water pump
Anthony Tedeschi
Water pump
Post by Anthony Tedeschi »
Has anybody put a auto water pump on a right hand motor?wander if it well circulate going the wrong way
k9th
Post by k9th »
I guess my question would be is there a reason why you don't want to put the correct water pump on?
Anthony Tedeschi
Quarter the price
k9th
Post by k9th »
While the pump may technically work some, I don't think anyone here is going to recommend that you do what you are thinking about doing. You ought to replace the pump with a legitimate equivalent replacement - your life may depend on that pump someday. Saving money now may be very expensive later in more ways than one.
Save a few bucks and then over heat the engine , thats not saving money .
some marine pump will work ether way dur to a neutral impeller angle , automotive pumps are not set up that way , made to pump one way only . if the engine is raw water cooled the impeller will rust away
rbcool
Post by rbcool »
Many years ago on my deck boat w/OMC 5.7 I put an automotive pump on. Worked GREAT!!!!!! (for a month)
Had to paddle almost 2 miles on the Indian River Bay
Ron 8)
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
Upper Bay, Chesapeake Bay
Post by Paul »
I have put an automotive left hand circulation pump on a right hand rotation marine engine. (350 cid GM) The pump had a centrifugal impeller with blades angled for left hand rotation. The result was no problem cooling the engine at 1500 rpm and up. Running at lower rpms, like in a marina or just idling, the engine would heat up.
I would not recommend doing this. Your better off installing the correct marine pump with the blades angled for right hand rotation or in the straight (neutral) position.
Hope this helps :D
gettaway
Post by gettaway »
go to sierra and order the correct on, we're talking 100 bucks, but if you have port supply at west marine, much less...
http://www.marineengine.com/parts/sierr ... arts/8024/
