AARON'S ANNOUNCEMENT..... I'VE FOUND 'HER' ! LONG STORY!!
wowzer52
Post by wowzer52 »
Congrats Aaron on your new boat. It sounds like there may be an unseen reason for you to own that boat. What an awsome blessing. :D CAP'N, we need pics, lots of pics.
1975 F-32 "SIMPLY BLESSED"
aaronbocknek
Post by aaronbocknek »
k9th wrote:
alexander38 wrote:What size engines do guys have in your tri's. Mine has has 454's and burns 20 gph at 14 knots and 21,000 lbs . Burn rate is est. off usage.
I have the twin Merc 255's. As I said mine do 18kts @ 2,900RPM and burns 25GPH. I established my burn rate during a 680 mile trip to bring her home when I first bought her. My owner's manual lists performance numbers for all engine packages offered that year and are very accurate.
sorry for the delay :( i have pleasure craft marine (they build crusader engines too) sea max engines that were put in the boat in 1998. rated at 250hp on a ford 351 block. as for fuel burn etc, i have no clue yet. it's all part of the fun learning curve.
aaronbocknek@gmail.com
Learning the fuel burn is not the "Fun part" of the learing curve
k9th
Post by k9th »
prowlersfish wrote:
aaronbocknek wrote:
k9th wrote: I have the twin Merc 255's. As I said mine do 18kts @ 2,900RPM and burns 25GPH. I established my burn rate during a 680 mile trip to bring her home when I first bought her. My owner's manual lists performance numbers for all engine packages offered that year and are very accurate.
Its usually the very expensive part of the learning curve.
