Trim Tabs
Trim Tabs
I have a question on my boat leveler trim tabs. Can I use transmission fluid in the reservoir? or do I need something else? Thanks.............John
1998 Kawasaki ZXi 1100
yes also.
in case you have no info on the trim tabs. here is a link to the insta trim website the manufacturer, under the BLEED section it also gives atf as the optional fluid
http://www.insta-trim.com/install.html
1997 CARVER 405
"the BLACK PEARL"
past fleet
1978 F32 SEDAN CHRYSLER 318's
current fleet
1997 seadoo gts
1997 yamaha wave venture
1985 sunbird 18 ft runabout
1968 coronado sailboat 25 ft
sunfish
14' hobie cat
canoe
8ft portabote
"the BLACK PEARL"
past fleet
current fleet
1997 seadoo gts
sunfish
14' hobie cat
canoe
8ft portabote
Works fine, did that this year when i replaced the hoses.
Aaron
____________________________
1975 36' Tri Cabin
"Keep it up!"
E-Mail : aweimer@comcast.net
Lake Erie, OH
1975 36' Tri Cabin
"Keep it up!"
Lake Erie, OH
