you started this topic on july 1 have you found a solution to your fuel problem?
http://www.trojanboatsforum.net/wforum/viewt ... 84ca22463b
daddysgirl
daddysgirl
1997 CARVER 405
"the BLACK PEARL"
past fleet
1978 F32 SEDAN CHRYSLER 318's
current fleet
1997 seadoo gts
1997 yamaha wave venture
1985 sunbird 18 ft runabout
1968 coronado sailboat 25 ft
sunfish
14' hobie cat
canoe
8ft portabote
"the BLACK PEARL"
past fleet
current fleet
1997 seadoo gts
sunfish
14' hobie cat
canoe
8ft portabote
DaddysGirls
glad you found the problem. is this from one of the tanks under the cockpit?. sure doesnt look like there is enough room under there to remove it without bending. are your tanks the original round 62 gal tanks? what did you make your pickup from? copper tubing? and what size?
1997 CARVER 405
"the BLACK PEARL"
past fleet
current fleet
1997 seadoo gts
sunfish
14' hobie cat
canoe
8ft portabote
"the BLACK PEARL"
past fleet
current fleet
1997 seadoo gts
sunfish
14' hobie cat
canoe
8ft portabote
DaddysGirls
It was the 62 gal tank, port side under the cockpit. We took the floor up & had a pretty straight shot at it. We used half inch copper.
g36 wrote:glad you found the problem. is this from one of the tanks under the cockpit?. sure doesnt look like there is enough room under there to remove it without bending. are your tanks the original round 62 gal tanks? what did you make your pickup from? copper tubing? and what size?
yeah i was wondering if the floor had to come up. not to big a deal for mine with the floor hatch being screwed down too.then it would be a straight shot to the tank. since i hadnt done it didnt know if there was a way around that. thanks for the reply
1997 CARVER 405
"the BLACK PEARL"
past fleet
current fleet
1997 seadoo gts
sunfish
14' hobie cat
canoe
8ft portabote
"the BLACK PEARL"
past fleet
current fleet
1997 seadoo gts
sunfish
14' hobie cat
canoe
8ft portabote
