LEAKING HOLDING TANK
1985 Trojan International has a leak in holding tank. Please let me know if you have any suggestions in how to replace or repair.
If it's not a leak by one of the fittings, then it should be replaced (poly-plastic I assume??). Option 1 is do it yourself. Option 2, which is what I prefer: A. Get big bag of money, B. Have nearest marina replace yucky holding tank and replumb any hoses, fittings etc, where needed. C. Give big bag of money to marina. Results = enjoying the boat again.
Randy P
1977 F-26 HT
"Blue Heron"
1977 F-26 HT
"Blue Heron"
Rodman
randyp wrote:If it's not a leak by one of the fittings, then it should be replaced (poly-plastic I assume??). Option 1 is do it yourself. Option 2, which is what I prefer: A. Get big bag of money, B. Have nearest marina replace yucky holding tank and replumb any hoses, fittings etc, where needed. C. Give big bag of money to marina. Results = enjoying the boat again.
I noticed my tank was leaking I found the hose coming out the tank to the pump was split. So I replaced the line and all is well.
Trojan
Built in tank or mid cabin model?
If it is the built in tank, the problem is probably sealant deterioration on the fiberglass lid, as it was with mine from excessive use of formaldyhde chemicals after hurricane Charley.
I noticed my tank was leaking I found the house coming out the tank to the pump was split. So I replaced the line and all is well.
wow!!! no wonder it split if it had a house coming out of it. now thats alot of poop
1997 CARVER 405
"the BLACK PEARL"
past fleet
1978 F32 SEDAN CHRYSLER 318's
current fleet
1997 seadoo gts
1997 yamaha wave venture
1985 sunbird 18 ft runabout
1968 coronado sailboat 25 ft
sunfish
14' hobie cat
canoe
8ft portabote
"the BLACK PEARL"
past fleet
current fleet
1997 seadoo gts
sunfish
14' hobie cat
canoe
8ft portabote
Rodman
g36 wrote:I noticed my tank was leaking I found the house coming out the tank to the pump was split. So I replaced the line and all is well.
OK I fixed the typo....
Trojan
I thought he meant an OUTHOUSE!
Danny Bailey
