The Norwegian Trojan.
pk,
Do you build an A frame over the boat to suspend the plastic/tarp so that snow will fall off and not collect? That is how we do it in Ontario, Canada when we store outside in the winter.
PK, I don't know how it is in Norway, but here in the states if you don't work on your own boat you had better have very deep pockets. The mechanics here get an average of $90.00 to $100.00 an hour and the cost of repairs can run up very quickly. At our marina they get from $300.00 to $1000.00 just to winterize a boat depending on what you have done.
PK,
that broken hose is the overboard drain for the sink in the head.
Given the age of the boat it might be a good idea to inspect or even simply REPLACE all of your bilge hoses and drain hoses.
You have drain hoses from the sinks, and the deck hatches.
Of vourse there's that window project as well...
Good Luck to you,
Good Luck to you,
Thanks RWS. I guess I need all the "Good Luck" you can give me. I also need a BIGGER bank account......
Today I have delivered all my broken windows to a company here in Norway. Actually in a town quite near me. They asked for something around $1200,- for new windows, plus a little amount for straightening the frames. Tomorrow I will buy a new toilett, an electric one I think. And several meters of hoses. I have to hurry up, the summer is coming.....
sounds like a good deal on the windows.
As far as the toilet is concerned, you might be surprised at how little it would cost to restore that Vac U Flush system.
In my opinion the Vac U Flush is the most long term trouble free unit on the planet.
Ask around...
Ask around...
Wes: Where on the tank is the sensor?
Is there anyone out here on the forum that knows anything about the Navistar 7,3 litre diesels from Ford? i.e. fuelconsumption, the power, and so on?
Tomorrow will be an quite nice day here on our side of the world. I will start the polishing work outside, have got yes from my "queen", she will help me out. At least with the washing. And I will try to remove all the old pipes and stuff in the engine room. I will put out some picks here tomorrow..... Gosh! I´m looking forward to put the boat into the water again!
the best diesels for the 10 meter are the Yanmar & the Cummins.
The problem with the Cimmins is height overall. Significant modifications will be needed. The Volvo engine is just too tall to fit at all.
You will find the waste tank floaat switch sensor on the center "floor" of the engine room. That floor is actually the tank lid.
The sensor will be located forward, close to the fwd engine room bulkhead.
If you rebuild the toilet valve and seal and replace the vacuflush pump & sanitation hoses your waste system should perform as new.
RWS: Do you know what kind of modifications I´ll have to do if I use the Cummins? Ofcourse it depends on type of Cummins, but I presume it is the 300 Hp?
Is there any lid under the wooden floor, at the top of the holding tank? If not, would´nt the odor and smell come up and around in the boat?
