Fuel Tank Sending Unit
Rich Schwochow
Has anyone had to replace the original AC brand fuel gauge tank sensor on the F series. I know it is a resistance sensor and I believe it's rated for 35-240 ohms, to operate properly on the original AC guages. I can't seem to find one in the various catalogs.
1978 F-32 Starship II
Rodman
Re: Fuel Tank Sending Unit
I am having problem with mine also. What can I do to check it?Rich Schwochow wrote:Has anyone had to replace the original AC brand fuel gauge tank sensor on the F series. I know it is a resistance sensor and I believe it's rated for 35-240 ohms, to operate properly on the original AC guages. I can't seem to find one in the various catalogs.
Trojan
Rich Schwochow
It needs to be checked with an ohm meter, with the sender out of the tank. One lead of the meter goes to the electrical post, the other to the flange or bracket,(ground). The ohms will change as you raise and lower the float. It should read somewhat stable in a fixed position. I believe it should read in the 40s or 50s range as empty, and in the mid to upper 100s when full. Mine reads all wacky.
Rich Schwochow
sending unit
Hey GO, what parts store and how much?
Here's some good info on testing.Rodman wrote:I am having problem with mine also. What can I do to check it?Rich Schwochow wrote:Has anyone had to replace the original AC brand fuel gauge tank sensor on the F series. I know it is a resistance sensor and I believe it's rated for 35-240 ohms, to operate properly on the original AC guages. I can't seem to find one in the various catalogs.
http://www.downloadingfiles.co.uk/telef ... ystems.pdf
Rodman
Stripermann2 wrote:Here's some good info on testing.Rodman wrote:I am having problem with mine also. What can I do to check it?Rich Schwochow wrote:Has anyone had to replace the original AC brand fuel gauge tank sensor on the F series. I know it is a resistance sensor and I believe it's rated for 35-240 ohms, to operate properly on the original AC guages. I can't seem to find one in the various catalogs.
Thanks this is good information.
Trojan
Rich Schwochow
sending unit
Testing it is not the problem, that I've done. Replacing it is what I'm looking for. I'd rather use an AC brand part if possible and not a Tempo brand.
Re: sending unit
Well then why not call Beacon or Marine Tech for the sending unit? I'm not sure that the sender was manufactured by AC, even if the gauges were. They should be able to tell you the specs, part numbers, etc.Rich Schwochow wrote:Testing it is not the problem, that I've done. Replacing it is what I'm looking for. I'd rather use an AC brand part if possible and not a Tempo brand.
Also, I posted the testing info for all, as well.
