stbd 454 340/mei merc.
Here's the trouble. engine will not run at w.o.t. the r.p.m. goes up and it drops right off and won't come back up.It will run at about 2k rpm just fine.
and it acts the same on the port tank,And the port engine runs fine on the stbd tank.
things that already have been done.
new filters
tune up
new carb.
and did a squeeze test on the cylinders and all come up to 137 psi plus or minus 4 pounds. eng. has 905 hrs on it.
my thoughts are weak fuel pump, or the ecm (more or less a timing spark box.) it's an 1987 with MEI has gone bad and won''t advance the timing.
new filters
tune up
new carb.
Sounds like the same trouble I'm having with my starboard 454. It runs fine at idle and then when I try to accelerate she will die (vapor lock?) If I pour fuel into the carb and get her running again she'll run fine the rest of the day. The only thing I haven't changed is the fuel pump. It is a pain to get to. I might try an electric fuel pump after the rendezvous.
there's also a filter in the fuel inlet of the quadrajet carb.
Three filters total on the International.
Ok here's what I did this weekend
All 3 anti-siphons work.
Fuel fitters are clean and no water.
Timing at 11 degrees before TDC.
But one thing on that everything I've read on thunderbolt IV high energy ignition said to ground a purple wire. The only on it goes to the coil. Gray wire to coil. Red and white / green and white go to dis/cap. And some info called for a purple and white comming from in that needed to grounded but there's not one on the d*#* thing. The reason for grounding is to set base time and the ecm won't try to override you when you adjust it. Any thoughts ?
another item to check is the MECHANICAL spark advance.
I found mine partially inoperable when I bought the boat.
The use of an ADVANCE timing light with an advance knob helped me to confirm and fix that problem.
- guglielmo6160
Hey guys replaced the gas pump today, after trying everything else what a p.i.t.a. but its done. the engine sounds like a new one.
Still have to take her out and do a run but it reacts a whole lot better.
I do think the old pump was bad. I can push the pump by hand and the new no way in he(! I just hope it's fixed. been fight this for 2 months. still going to replace the coils they've got to be tried, thoughts on high out put JEG's or MSD's
Still have know ideal how to set up the thunderbolt IV mei for timing. I did find out they made two of them. I've got the first ones they made with just 4 wires then it switched to a 5 wire the 5th wire is for timing. I'm thinking about getting a advanced timing light and check total timing and see how it looks. I don't hear a miss in it when I sit base 11 btdc I just want to know it's right.
and thanks for the in put
