swim platform risers
gofish103
Post by gofish103 »
I sanded and cetoled my swim platform this week and looks awsome. today i removed the teak risers after having to chisel the rusted bolts off. well no surprise the ends of the risers that go into the brackets located on the transom were pretty rough.
can I use an epoxy to repair the ends??? I live in Columbus, Ohio and I dont know where to buy teak to make new risers>>
what do you mean by risers ? if your talking about the supports I would replace with SS tubing if you can .
gofish103
Post by gofish103 »
they are the wood risers that support the swim platform, they are approximately 2"x2", of various lenghts, and there is 5 of them.
I never thought of using stainless tubing. any idea where I could get that??
Peter
Post by Peter »
if you want to replace with teak,search ebay,"teak lumber"...world panel has large boards for sale,as do other venders.can usually get a very good deal.
You can get ss tubing at most marine stores in 1 inch round ( will be plenty strong 2x2 teak will cost ya , ( not that SS is cheap )
lumber on ebay ? why not I will have to check it out
mtwolf
Post by mtwolf »
I have used epoxy mixed with saw dust for wood repairs. I wouldn't think you would see the repair anyway if it's under the bracket. I had a friend that did that on his Chris-Craft wood boat. Worked like a charm. He was the one that put me on to it. Repair is stronger than the original wood.
John
F-31
Middle River, MD
wowzer52
Post by wowzer52 »
Any canvas shop has stainless tubing in many diameters and wall thicknesses and you can usually get scraps real cheap that will be long enough. They can also bend it for you and have any fittings you might want.
1975 F-32 "SIMPLY BLESSED"
gofish103
Post by gofish103 »
Hey guys thanks a million for all the input. Im gonna check out the SS tubes and I am also gonna try and repair what I have with the epoxy and sawdust mix. I sanded down the swimplatform and saved the saw dust.
I really like the look of the wood risers on this classic.
AndyF32
Post by AndyF32 »
I am not sure how the risers fit into the lower brackets but as long as the area is in compression the epoxy alone will work fine. If you are using epoxy in tension you will need to add fiberglass cloth to provide strength. It is very similar to concrete good in compression but needs help in tension.
gofish103
Post by gofish103 »
the brackets are cupped and the riser ends fit into the cups and are held in with a nut and bolt.
AndyF32
Post by AndyF32 »
So the bottom of the risers are in the cups and pressure of weight on the platform pushes them down into the cups? If that is the case they are in compression and the epoxy will work fine.
gofish103
Post by gofish103 »
andy
yes thats how they work, there is a thru bolt that holds them in place. some of the bolt holes are oblonged, If I fill the bolt hole with the epoxy is it ok to drill em back out???
AndyF32
Post by AndyF32 »
Yes it is. That is exactly how you use epoxy to seal a hole thru a cored area. In a cored area you would drill an oversize hole, fill with epoxy, then drill the correct size hole.
Dan Faith
Post by Dan Faith »
Where to you boat? Up on Lake Erie, Sandusky area you can get whatever size teak you want cut and planed very reasonable. Homestead hardwood.
Here is the link
http://www.homesteadhardwoods.com/random.html
teak is towards bottom of the page.
Dan Faith
Toy Box
Trojan F32
Trojan 30' sport fisherman
Sea Ray 17'
Beach Craft Bonanza N35
Corvette
Peter
Post by Peter »
been there...like a kid in a candy shop....
