Deck repair option Injectadeck
Like many other older boats I found my Trojan suffering from soft bow disease. Did not look forward to cutting the top glass open, So I looked at different options. Living with it? Paying someone? After much research, I decided on "Injectadeck". Reviews were mixed, but found the negative ones never used the actual product. Also spoke with several users (2 on here) They were positive. I expect some negative comments, but let me be clear about what Injectadeck is and is not. Injectadeck is a 2 part structural expanding foam water helps in the cure. It is a closed-cell foam. It flows and expands in voids and displaces mussy balsa. What it is not. It is not an epoxy or an open cell foam like great stuff or other 1 part foams and it's not Gorella glue.(but has some similarities). I drilled the holes to 3/16 and after filling very hard to see. Deck feels good now, would I use it again? Yes
- deck repair.jpg 2.jpg (64.62 KiB) Viewed 29275 times
- deck repar 4.jpg (76.24 KiB) Viewed 29275 times
- deck repair.jpg (57.43 KiB) Viewed 29275 times
- deck repaire done.jpg (57.44 KiB) Viewed 29275 times
- Small_Kit-2.jpg (23.83 KiB) Viewed 29275 times
Re: Deck repair option Injectadeck
Looking good. I’ve repaired sections of the bow deck by removing the top fg layer with a vibrating saw, replaced the punky balsa core with like material, epoxy coat the balsa, overcoat the balsa and replace the deck section, saving the nonskid pattern. Ran a thin bead of West epoxy in the saw lines, using their caulking tube with mixing tip. So far came out good, and I’ve done it to 2 places with one or two to go. I repainted the bow deck with Petit EZ Poxy. Looks almost original. I Ike your approach, though. Next summer I’ll give it a try.
‘77 F26 HT Since 1999
Thank you. I am pretty pleased with it so far. Cutting it open is the best way, but it's a lot more work and you need days of good weather. This is pretty easy and goes pretty quickly. And I have heard from others it's holding up well over time. For this old guy, it was the right choiceBoppy wrote: ↑Tue Oct 03, 2023 3:06 pm Looking good. I’ve repaired sections of the bow deck by removing the top fg layer with a vibrating saw, replaced the punky balsa core with like material, epoxy coat the balsa, overcoat the balsa and replace the deck section, saving the nonskid pattern. Ran a thin bead of West epoxy in the saw lines, using their caulking tube with mixing tip. So far came out good, and I’ve done it to 2 places with one or two to go. I repainted the bow deck with Petit EZ Poxy. Looks almost original. I Ike your approach, though. Next summer I’ll give it a try.
What did you finish off the deck with after you sanded down the foam? And aslo I assume that product doesnt conitnue to exband?
Being a 2 parts the foam expands and cures quickly. I clean out the 3/16 hole and fill it with epoxy.
Thanks for the info and answers on this product. I may try it on the future. I just dont want to run into any lumps from the application as it expands and moves.prowlersfish wrote: ↑Wed Oct 04, 2023 9:12 am Being a 2 parts the foam expands and cures quickly. I clean out the 3/16 hole and fill it with epoxy.
There is a danger of that so you need to keep a lookout, you can deal with it as in cures. Honestly, I think I can feel a very slight lump in one area, can't see it. And never felt for any before.Martino wrote: ↑Wed Oct 04, 2023 10:18 amThanks for the info and answers on this product. I may try it on the future. I just done want to run into any lumps from the application as it expands and moves.prowlersfish wrote: ↑Wed Oct 04, 2023 9:12 am Being a 2 parts the foam expands and cures quickly. I clean out the 3/16 hole and fill it with epoxy.
Just updating the repair has held up well so far.
