1972 F36
Am I missing something? My freshwater tank is leaking and it appears to me the only way to access it is to cut the floor.Is there another way?
Access fresh water tank
Re: Access fresh water tank
The floor is screwed down . It is plywood , whatever flooring you have is likely cover the plywood and the screws .
You said F36 and I responed thinking you have a F36 meaning a sedan
If its a Tri cabin then I don't know .
Please be clear on the boat you have .
- WayWeGo
If you put your boat in your signature, people will stop asking what boat you have!
Agreed along with engine info . FWIW its a tri cabin ( saw FB post ) so I wasted my time .
