F32 Stringers Replacement
Built an A Frame to pull the motors. Then some bulkhead and stringer repairs and a fresh coat of Bilge paint. More pics to come.
- IMG_20200516_141215182_HDR.jpg (69.1 KiB) Viewed 32324 times
Re: F32 360 Motors coming out and Bilge Rejuvenation
Did you run into any issues lifting them out with the A-frame? Any notes on position or additional support underneath?
Currently Trojan-less
- P-Dogg
One word: Ugh!
Lot of work . are you and Martino the same ?
buffalobill
Wow, that looks bad. Could you post pics during replacement? Would you consider steel fabrication along with the new wood? What bilge paint do you use? Thanks.
Well during the summer I made new stringers.
Created templates out of foam insulation board and then transferred them to 3/4 inch Marine ply.
I bonded 4 layers of ply to create 3 inch wide stringers. Bonded the stringers in the hull and then will encapsulate them in fiberglass.
- IMG_20201017_162954738.jpg (101.85 KiB) Viewed 31025 times
- IMG_20200913_163858879.jpg (58.73 KiB) Viewed 31025 times
- IMG_20200913_163849745.jpg (53.57 KiB) Viewed 31025 times
- IMG_20200905_181525997.jpg (110.95 KiB) Viewed 31025 times
- IMG_20200728_184656758.jpg (135.49 KiB) Viewed 31025 times
- IMG_20200728_184640258.jpg (125.93 KiB) Viewed 31025 times
- 16397.jpeg (140.19 KiB) Viewed 31025 times
More pics of the bonded stringers
- IMG_20201018_171035066.jpg (113.2 KiB) Viewed 31025 times
- IMG_20201018_171028009.jpg (94.56 KiB) Viewed 31025 times
- IMG_20201017_163002225.jpg (111.88 KiB) Viewed 31025 times
- IMG_20201017_162957556.jpg (118.77 KiB) Viewed 31025 times
I wouldn't use steel as a replacement. I think it would be to heavy.buffalobill wrote: ↑Thu Aug 13, 2020 9:39 am Wow, that looks bad. Could you post pics during replacement? Would you consider steel fabrication along with the new wood? What bilge paint do you use? Thanks.
Re: F32 Stringers and Motors Replacement
You sir, are a better man than I.
That is an impressive amount of work! Best of luck!
1987 F32
All Wrapt Up
Kent Narrows,Md.
All Wrapt Up
Kent Narrows,Md.
That is some nice work !
Thank You ! I'll admit it isn't easy !! Very Labor Intense !
Bonded another stringer down last night ! One more piece to go tonight then the encapsulation starts.
- IMG_20201019_175143582.jpg (59.35 KiB) Viewed 30932 times
- WayWeGo
Re: F32 Stringers Replacement
Very nice -- thanks for documenting here so others can see how to do it!
