10 meter sedan 1986. Model 350
Kjpv2b
Post by Kjpv2b »
Hello all. Have myself a 10 meter sedan with mercruiser 350..? Anyone else have these engines? Majority seems to be 454s. Don’t know anything about the boat since the guy I bought it from was a broker and just needed to get rid of it. Both engines did run when I bought it, compression test were good except for one cylinder that had a lower compression than the others, I think 10psi... thank uou
Re: 10 meter sedan 1986. Model 350
Most had crusader 350hp 454s . I don't recall anyone with mercs posting . Are your mercs 350 hp or 350 ci ? Engine photo ? Bob at Beacon can tell you what the boat came with from Trojan
Kjpv2b
Post by Kjpv2b »
Here are the pics. Sorry took long to reply. Just busy with work and other things breaking down.
Here are the engines.  I don’t see many here with 10 meter sedans. Is it not a good type or just not very popular?
Your Engines are Crusaders 454s and 350 hp not mercs . This is the engine Trojan put in the 10 meter . Crusader model 350 is indeed a 454 cid .
dakotamusic12
Post by dakotamusic12 »
I have the same year and model. Those are 454's for certain. Great boat!! They are extremely popular and hard to find as most keep them many years. There are plenty of express 10 meters but the sedan has great lines, very sea worthy. Read the write up by Dave Pascoe on the 10.8 you'll be glad you scored that boat.
I've owned mine 18 years now.
Original owner owned her for 18 as well.
Lots of info can be found here, including the Pascoe article:
www.trojanboat.com
