10 meter express part Trojan forgot to build
my10meter
Ever since getting my 10-meter I was always annoyed by the open space in the back of the bilge. Anytime you try to work your feet had a small lip to stand on. I could not bring it to myself to just put a piece of wood across it, as you can see by the pics , I finally installed a very nice fiberglass pulltruded Extrusion grate. It looks good is very strong and has a non-slip surface. It is easily removable, and the high water float still works with it installed. I had to purchase a full sheet to do this and have extra material.(expensive material) If anyone would like one, I would sell them for $50 a piece plus shipping , not looking to make money on this just trying to recoup some of my expense. I will donate $5 to the site for each purchase
. The width is 28 inches, and to cover the entire area it would be about 27 to 28 in Long.(unless you have a genny or a/c as mine is) Just contact me and let me know what size you need. Call/text 6166386145 first come first serve until my material is gone. Thanks
- 20190417_132238.jpg (66.84 KiB) Viewed 4040 times
- 20190417_124858.jpg (66.83 KiB) Viewed 4040 times
Re: 10 meter express part Trojan forgot to build
That looks great!!
I cut some Rigidex 874010 Moldtruded Grate to fit in mine. It is antiskid texture on top, and is impervious to almost all chemicals, and can hold up my big butt.
MyTenMeter
Very nice work. great solution to a problem.
I wonder what percentage of 10 meter expresses were sole without the gen set?
LOTS OF SPACE back there for inverter batteries...…….
