Help... IT's STUCK!!! Waste Tank fitting
Resolute
Post by Resolute »
I am trying to remove the vent/level indicator for the waste tank in my 10 Meter Sedan, but unfortunately I am not having any luck. This looks like it screws on, but my attempts to unscrew it by hitting the tab edge with a hammer/screwdriver have proved unsuccessful. Has anyone removed this before? Am I trying to unscrew something that simply pops off. Any advice would be greatly appreciated. Thank you.
1985 Trojan International 10 Meter Flybridge Sedan - 454 Crusaders
mike0469
Re: Help... IT's STUCK!!! Waste Tank fitting
Post by mike0469 »
Try a plumbing Strap Wrench; can purchase from Home Depot or Lowes.
Mine was on real tight. I used PVC Slip-Joint Pliers from Home Depot.
Resolution, Resolute?
tcollins2
Post by tcollins2 »
It definitely unscrews. No doubt it's on tight. Large slip pliers will do the job. If you break it this might be your replacement.
The picture shows that it's threaded.
https://www.marinepartssource.com/domet ... gKe1fD_BwE
