Cappy's f32 rehab
Captrichc
Re: Cappy's f32 rehab
Post by Captrichc »
El L Sea wrote: Thu Feb 21, 2019 12:54 pm We use products from Yacht Devices. They are easy to hook up and they make a wide range of not only sensors, but control products for NMEA2000.
How do those hook up?
1974 f32 Sedan
Twin 233 Mercruisers
Captrichc wrote: Thu Feb 21, 2019 6:01 pm
Directly to the NMEA backbone, that's why I like them. This is my engine room temp sensor.
Captrichc
Post by Captrichc »
Simrad system will be delivered today. Cant wait to set it up. I want to redo the witing b4 i seal the deck again for easy access.
Also i designed my new hatch. I will post pics later tonight
1974 f32 Sedan
Captrichc
Post by Captrichc »
Here are some pics of the new system.!!!!
1974 f32 Sedan
Captrichc
Post by Captrichc »
Now i need to figure out where to mount the total scan transducer.
1974 f32 Sedan
Very nice
I have the same radar and like it a lot. If only I knew how to take advantage of all its features. Then again, I really enjoy learning how to use it! :wink:
Captrichc
Post by Captrichc »
WayWeGo wrote: Tue Feb 26, 2019 6:00 pm I have the same radar and like it a lot. If only I knew how to take advantage of all its features. Then again, I really enjoy learning how to use it! :wink:
I cant wait to set mine up.
1974 f32 Sedan
Captrichc
Post by Captrichc »
Ordered my nmea 2000 network today, along with the Nolan rs11, 2 lowrance fuel flow sensors. My birthday came a few days early
1974 f32 Sedan
Captrichc
Post by Captrichc »
Both new tanks are installed and all hoses ran. Reimstalled pressure pump for fresh water and installed the saltwater wash down pump. Tomorrow ill take up the electric for everything and stsrt the template for the floor.
1974 f32 Sedan
You're on a roll! Keep up the good work and thanks for keeping us in the loop!
Captrichc
Post by Captrichc »
Just picked up my props they look almost brand new.
1974 f32 Sedan
Captrichc
Post by Captrichc »
Cleaned up the wiring today. Ill take some pics once i have everything mounted where it needs to be b4 i make the template for the floor itself.
1974 f32 Sedan
Captrichc
Post by Captrichc »
Template made for the floor. Cut the wood and i am going to be installing the deck today.
1974 f32 Sedan
Captrichc
Post by Captrichc »
Some new pictures.
1974 f32 Sedan
