Cappy's f32 rehab
Captrichc
Re: Cappy's f32 rehab
Post by Captrichc »
Ran all of the new fuel lines. And just about ready for final install of fuel tanks. Need some recommendations on how to plumb a generator that i might be getting my hands on. 6.5kw kohler cz. Do i plumb before or after the fuel filters? If its after will it steal pressure from the engine?
1974 f32 Sedan
Twin 233 Mercruisers
BradZ
Post by BradZ »
Lets see some pictures Captrichc…. We love progress pictures... Well at least I do.. lol
My generator has a separate pickup from the tank. Not familiar enough with your setup to make a recommendation, but consider how little fuel the genny uses while running. 1.3 gal/hr leaps into my head for a similar size generator. Probably an inconsequential amount. Depends on how oversized your propulsion engine lines are. You can probably look up fuel consumption rates on ye olde internet.
And you'll want read the ABYC fuel system standard. Note that my boat has a solenoid that shuts off fuel except when genny is operating.
The right way is for the generator to have its own fuel pick up , lines and filter . Normal practice is to have the pick up higher for the gen set so you can't run the tank dry. If you use the same pick you can run into issues . A slightly leaking check valve in the fuel pump can cause the other engine (main or gen) to suck air and run dry . And the could compete for fuel . With that said I have seen it done with no issues and seen issues because it was done . Good chance one or more of your tanks has a place for a extra pick up .
If you must share the pick up put a shut of on both lines
Captrichc
Post by Captrichc »
BradZ wrote: Sun Feb 10, 2019 8:25 pm Lets see some pictures Captrichc…. We love progress pictures... Well at least I do.. lol
Pics to come i promise. Been crazy with work and the snow. I haven't recieved the genny yet. Just trying to plan ahead a little bit if i can
1974 f32 Sedan
Captrichc
Post by Captrichc »
prowlersfish wrote: Sun Feb 10, 2019 9:39 pm The right way is for the generator to have its own fuel pick up , lines and filter . Normal practice is to have the pick up higher for the gen set so you can't run the tank dry. If you use the same pick you can run into issues . A slightly leaking check valve in the fuel pump can cause the other engine (main or gen) to suck air and run dry . And the could compete for fuel . With that said I have seen it done with no issues and seen issues because it was done . Good chance one or more of your tanks has a place for a extra pick up .
I would add a T and shut off to both lines. Speaking of i need to order my inline shut off valves for the new fuel lines. Glad you reminded me.
1974 f32 Sedan
Captrichc
Post by Captrichc »
Here are some pics from today.
1974 f32 Sedan
Captrichc
Post by Captrichc »
More pics
1974 f32 Sedan
Captrichc
Post by Captrichc »
Just purchased the Simrad Go12xse. With total scan, and 4g radar. I am extremely excited about this. Does anyone else have experience with the go series by Simrad?
1974 f32 Sedan
I don't have go series, but do have a Simrad NSS Evo 2 MFD with 4G radar and lots of other Simrad and B&G gear. I have done quite a bit of integration and troubleshooting getting it all working the way I want, along with many calls to Simrad's tech support.
If I can be of help, let me know here or by PM.
Captrichc
Post by Captrichc »
WayWeGo wrote: Wed Feb 20, 2019 2:30 pm I don't have go series, but do have a Simrad NSS Evo 2 MFD with 4G radar and lots of other Simrad and B&G gear. I have done quite a bit of integration and troubleshooting getting it all working the way I want, along with many calls to Simrad's tech support.
Thanks!! Would love to figure out the engine monitoring features as well. Through the nema2000 system. If you have any information on this please send my way.
1974 f32 Sedan
I have a Noland Engineering RS11 interface that I will be using for RPM, oil pressure, coolant temperature and exhaust temperature. It hooks up to the tach and gauges, and sends NMEA2000 to the chart plotter. For exhaust temperature, I bought Blue Sea 1821 senders on sale from Defender.
Captrichc
Post by Captrichc »
WayWeGo wrote: Wed Feb 20, 2019 11:53 pm I have a Noland Engineering RS11 interface that I will be using for RPM, oil pressure, coolant temperature and exhaust temperature. It hooks up to the tach and gauges, and sends NMEA2000 to the chart plotter. For exhaust temperature, I bought Blue Sea 1821 senders on sale from Defender.
The nolan rs11 works off the existing analog sender and guages?
1974 f32 Sedan
Yes, you connect it to the gauges and use a USB cable and PC to configure. I had to buy sensors for exhaust temperature because I didn't have them before. The cost of Balmor or Aqualarm exhaust temperature alarms is not that much less than the RS11.
We use products from Yacht Devices. They are easy to hook up and they make a wide range of not only sensors, but control products for NMEA2000.
