Trailers for Large Boats
- The Dog House
Does anyone on the forum trailer their boat, either in the marina yard or on the open road? What are you trailering and what trailers are you using? Is anyone using a "yard" trailer that isn't street legal to move their boat around the marina yard? Any recommendations for or against specific trailer brands would be appreciated.
Re: Trailers for Large Boats
Foofer b , used to tow his F26 . He had a aluminum bunk trailer . ( he sold it a few years ago )
I have a trailer that can haul up to a 36 X 15. I use is as a yard trailer for storage, but it is a "transport" trailer, meaning that the boat needs to be tavel lifted on and off. Can't slide it off on a boat ramp.
built this one out of a semi truck frame. worked out better than we thought. boat was floated onto trailer and tied down
- 2016-01-24 00.27.44 small.jpg (250.71 KiB) Viewed 10699 times
1981 Trojan 290
6.2 GM Diesel
6.2 GM Diesel
- Paul - SW Ontario
Triple axle trailer, floating adjustable bunks. (3500 lb.axles -two forward hydraulic braking)
Tow mine to and from its marina slip every year at start and end of season. Hauls beautifully with my 1/2 ton Lariat 4x4.
[img][IMG]http://i658.photobucket.com/albums/uu30 ... 1023-1.jpg[/img][/img]
1973 Trojan F25.5 - SW, ON.
2012 Triple Axle trailer
1978 C&C Mega 30' Sailboat
2014 Triple Axle trailer
2016 Highfield CL290 BL RIB
2017 20hp Suzuki 4 stroke
Trojan26NC
My F26 sits is on a trailer because of the brackish water of the Calabash River. It is a pain to move the boat because of width of the boat. In NC you have to have a wide load permit to move it. My brother found out the hard way. The trailer has 3 axles.
1978 Trojan 26
Twin 135HP Volvo's
Twin 135HP Volvo's
- The Dog House
I notice you have twins. What make is your trailer and how wide are the bunks? Do you have any trouble fitting the two shafts between the bunks? My current boat is a single screw, and I'm wondering if I move up to a twin screw if I'll still be able to keep it on a trailer. Our boat club has a launch ramp but does not have a Travelift. I would only be launching in the Spring and pulling it out in the Fall. The boat would be tied to the dock during the boating season.Trojan26NC wrote:My F26 sits is on a trailer because of the brackish water of the Calabash River. It is a pain to move the boat because of width of the boat. In NC you have to have a wide load permit to move it. My brother found out the hard way. The trailer has 3 axles.
Trojan26NC
My boat has twin Volvo Inboard/Outboards so no issues getting it on the trailer. The trailer has rollers instead of bunks. It also is not to bad to load on trailer with a buddy helping.
I don't see a lot of others with the twin IO setup.
1978 Trojan 26
Twin 135HP Volvo's
Twin 135HP Volvo's
fisherman1422
Would that trailer work towing a 30 foot twin screw 1980 Trojan. Looking to tow from North Kingstown, to North Kingstown. ASAP time is an issue
Not going to be easy to find , and you will need permits . height can be a issue . If this is a one time thing , look at a transport company
- Paul - SW Ontario
The Dog House wrote: ↑Fri Feb 05, 2016 9:00 pm Does anyone on the forum trailer their boat, either in the marina yard or on the open road? What are you trailering and what trailers are you using? Is anyone using a "yard" trailer that isn't street legal to move their boat around the marina yard? Any recommendations for or against specific trailer brands would be appreciated.
- IMG_0686.JPG (140.69 KiB) Viewed 10081 times
