Swim Deck Project
Lance F28
Swim Deck Project
Post by Lance F28 »
I recently completed my swim deck project and wanted to share a few pics. I made a jig from 3/4" plywood to shape the deck to the curve of my transom. Then I clamped the 3/4"x2" red oak strips in place dry to number and mark the center line and cut outs. Then I took it apart and made the cuts for the drain cut outs but left the length to run wild.
Then I glued, clamped and screwed each piece using Tightbond Waterproof wood glue and stainless steel screws. I sealed the bottom side with fiber glass resin because the bottom will be hard to maintain. The top is planed, routed, sanded, stained and sealed with marine grade spar varnish. I have new stainless steel brackets and need to schedule the shop at the marina to haul the boat out so I can install.
Swim Deck 1.jpg (223.73 KiB) Viewed 8688 times
Jimmy
Re: Swim Deck Project
Post by Jimmy »
Looks awesome. Hope the varnish lasts.
1988 Trojan 11 Meter Express
Lance F28
Post by Lance F28 »
Thanks Jimmy, I hope it last too. I have a covered slip so it will not be exposed to the sun except when we are out using the boat and I plan to watch it pretty close and re-apply at least once a year.
oil&water
Post by oil&water »
That is an incredible job. It will look great behind your Trojan!
Currently Trojan-less :?
Lance F28
Post by Lance F28 »
Thanks Oil&Water I think it turned out good. I'm working on the wood transom ladder and will add it this weekend. Then I'll start the back wall of the cabin, door, window trim and other wood items.
Captrichc
Post by Captrichc »
Looks amazing . Did you have a hard time bending the strips
1974 f32 Sedan
Twin 233 Mercruisers
Merchdoor
Post by Merchdoor »
Wow. Not sure how long it took to make but the end result turned out beautiful. Great job.
Captrichc
Post by Captrichc »
I have a question.. was there a swim platform before you installed this? So what I'm asking was the hardware installed already. I'm looking to install a swim platform on mine but need to completely install from scratch.
1974 f32 Sedan
