32ft. Trojan Sports fisherman
thereach831
Need advice on removal of an apparent drain plug thru the bow hull.
- Moderator
- 2026 Support
Re: 32ft. Trojan Sports fisherman
I moved your post to the Trojan boat forum . If I recall its just a pipe plug that screws out . Some remove it while on land , just don't forget to put it back in .
Moderator
Forum Moderator
TrojanBoats.Net
Trojan Boater
Forum Moderator
TrojanBoats.Net
Trojan Boater
thereach831
Thanks for reply..Yes on land and I was able to remove male plug that screws into the thru-hull fitting,now the fitting is loose and will need to replace or repair.It has a large thin nut that screws to the outer threads of the fitting on the inside to secure what seems to be a rubber attachment on underneath portion of the fitting outside underneath.Removing the fitting will be tricky since the nut is so thin.I was wondering if this particular type of thru-hull fitting is still available for this boat(1971 Trojan fiberglass hull)and if you have any advice as far as repair/replacement and where to find fitting if available....Thank you very much....James
- Moderator
- 2026 Support
Give Bob at Beacon marine
Moderator
Forum Moderator
TrojanBoats.Net
Trojan Boater
Forum Moderator
TrojanBoats.Net
Trojan Boater
- Beacon Bob
Give us a call
609 713 4602
Beacon Marine
Ask for Bob
609 713 4602
Beacon Marine
Ask for Bob
