1980 F32 salon floor slightly rotted and soft
Martino
Post by Martino »
I just go this F32 in the fall and I discovered this soft floor board.
Any suggestions where the water is coming form?
[attachment=0]
Re: 1980 F32 salon floor slightly rotted and soft
Look around the rear glass and frame and the side glass
Also look for clogged drain holes at the base of the side windows at the back. Water runs to the back and if there is nowhere to go, it runs down the inside corner to the floor.
Is the floor of the cabinet also soft in the same area?
Martino
Post by Martino »
No, the cabinet area is not soft.
Martino
Post by Martino »
I'll have to check the floor inside the cabinet.
Martino
Post by Martino »
So the floor inside the cabinet is not soft?
Still could be rear glass or frame or the side glass , look for some stains .
Martino
Post by Martino »
prowlersfish wrote: Tue May 29, 2018 6:36 am Still could be rear glass or frame or the side glass , look for some stains .
Thanks for the advise.
I'll dive in deeper and see what I can find
Last bumped by Martino on Tue Jul 23, 2019 2:46 pm.
