FUSE OR BREAKER FOR FRIDGE ?
NOTHING ELSE MATTERS
Anyone knows if and where is the breaker or fuse for the refrigerator on a 1983 9 meter int'l express ?
There is nothing on the electrical panel.
Re: FUSE OR BREAKER FOR FRIDGE ?
sorry dont have your boat model but if theres not a specific ac breaker marked its probably piggybacked to a breaker that powers your galley outlets. i would think theres a dc fuse/breaker for it seperately in the dc panel, but who knows. you can pretty much bet there will be some protection fuse etc. somewhere may have to get a look behind the refrigerator for it. i didnt notice you mentioned what fridge model that could be helpful. not coming on could be a on/off switch or the thermostat inside turned all the way down keeping it from turning on
1997 CARVER 405
"the BLACK PEARL"
past fleet
1978 F32 SEDAN CHRYSLER 318's
current fleet
1997 seadoo gts
1997 yamaha wave venture
1985 sunbird 18 ft runabout
1968 coronado sailboat 25 ft
sunfish
14' hobie cat
canoe
8ft portabote
"the BLACK PEARL"
past fleet
current fleet
1997 seadoo gts
sunfish
14' hobie cat
canoe
8ft portabote
I think mine is 12 volt but it works with all the switches closed. Or maybe is only 110 volt, hmm, I will disconnect the shore power and see.
on the 1983 10 meter, 110 volt system, the port and starboard sides each have their own breaker.
NOTHING ELSE MATTERS wrote:I think mine is 12 volt but it works with all the switches closed. Or maybe is only 110 volt, hmm, I will disconnect the shore power and see.
It could be dual voltage 12 and 110 . What is the brand name and model on the unit ?
It is not 110 volt a/c. I disconnected the shore power, i shut the battery switches, but the fridge still going solid.
Any thing in the owners manual if it originally had a 12v fridge ? If it had one Trojan would have put a breaker on it and it would be listed in the wiring diagram . If not installed by Trojan I would start tracing wires to make sure it had one along with a switch to cut the power (or a switchable breaker )
Also the dual Voltage units will automatically switch over to 12 volts when you disconnect the shore power .
I am waiting for the electrical diagram for the boat.
I will check it then.
Pull the fridge out and check wires going to it with a volt meter. There also may be a fuse there inline. I asked earlier what fridge make model do you have? Would be easier to help.
1997 CARVER 405
"the BLACK PEARL"
past fleet
current fleet
1997 seadoo gts
sunfish
14' hobie cat
canoe
8ft portabote
"the BLACK PEARL"
past fleet
current fleet
1997 seadoo gts
sunfish
14' hobie cat
canoe
8ft portabote
I just turn the refrigerator off when not in use (used rarely) -- dial inside the freezer door on mine.
1980 F26, Mercruiser 305
