need help to find f32 exhaust bellows
lottanerv
Post by lottanerv »
Guys help!
I can't find a rubber exhaust bellows for my Chrysler 360 V in 1981 F32. It is rubber, 9.5 inch long, double hump, 3 inch interior diameter.It connects the port side engine elbow to the "T" pipe out the boat.
It is the original part that finally blow. I can't find it any where. Is there a suitable sustitute?
Hugh
F32 1981
Boaitng is escape
Re: need help to find f32 exhaust bellows
Try this link
www.tridentmarine.com
Are these the bellows you are looking for? From my '85 tricabin....
http://www.trojanboatsforum.net/wforum/viewt ... wow#p81910
http://www.purosil.com/product.php?cate ... ducts&id=3
I still have the black bellows that I took out. There is nothing obviously wrong with them, in case you are interested. I just wanted new.
lottanerv
Post by lottanerv »
Thanks. The black bellows may work for me. I require 3 inch interior diameter. What is it on your bellows adn what is the length ?
Hugh
Boaitng is escape
lottanerv
Post by lottanerv »
Thanks. The black bellows may work for me. I require 3 inch interior diameter. What is it on your bellows and what is the length ?
Hugh
Boaitng is escape
5" ID and free length of 8.5"
Purosil makes a 3" ID that looks like it could be 9.5" long. I had to cut-down the ones that I bought.
lottanerv
Post by lottanerv »
Thanks P Dogg, looks like Purosil has the bellows I need on their website. Did you use their product in your boat? Details pls.
Hugh
Boaitng is escape
aaronbocknek
Post by aaronbocknek »
lottanerv wrote:Thanks P Dogg, looks like Purosil has the bellows I need on their website. Did you use their product in your boat? Details pls.
Hugh
oh did he use that product on his boat............. just follow the link he posted in this thread. if anyone knows about a 'bellows replacement', perry is your go to guy. and i've actually SEEN the end result. in person, no less.
aaronbocknek@gmail.com
lottanerv
Post by lottanerv »
Thanks all for your responses. What a merry go round this has been trying to find the exhaust bellows for my f32 Chryslers. No body has this part. Purosil doesn't sell retail so they referred to several of their dealers. None stock the part nor does Purosil even though they show a part like it in silicone on their website. They take 3 weeks to manufacture the part if a dealer ordered it. I finally stumbled onto the original bellows on ebay and bought them.
This should serve as a heads up to all F32 owners with Chryslers. This part is not available....a work around will have to be found unless you get lucky as I did and find a good used bellows.
Boaitng is escape
This should be easy to find never had a issue when I need them , here is another brand I use .
http://www.tridentmarine.com/stage/wetex_elbows.htm
