matching teak plywood f36
8lug
Post by 8lug »
i have looked on this site and searched around a bit but didnt come up with much of anything
does anyone know what kind of plywood the bar wall or the plywood in the hallway is made of
or what type of plywood i could get to match the existing
i am wanting to do a couple built in places
for example in the 2nd stateroom i plan on putting a built in in the closet so the tv is flush mounted with a place under it for dvd
im doing everything in z-spar captains varnish heres a few odd and end pieces
if i buy pine plywood will the varnish make it match up
Re: matching teak plywood f36
Are you trying to match colour, grain, or both?
8lug
Post by 8lug »
not worried about anything but color
long as when you look at it it dont look obvious
did they use marine plywood
teak plywood
or pine
Pine will look yellow . teak or mahogany would be the closest . You can always stain to match .
LandVF36
Post by LandVF36 »
I've ordered the teak plywood from here before
http://www.buckwoodcraft.com/teak-venee ... thick.html
They boxed and shipped to any address with a dock. I think the last I bought was 4+ yrs ago and it was not cheap, but a perfect match to the teak in the boat.
Current Fleet:
2000 Carver 450 Voyager
1994 Scout 15'
2005 Caribe LCX9 dingy
1981 16' Hobicat
Might be a side track to what you are doing... but Cetol is a good 'evener'..... If you use regular Cetol vs varnish on most finishes, it ends up (after 3-4 coats) to take on pretty much the same colour. I have used it on Teak, Mahogany, and Oak... and after a few coats they all look the same (except for grain).
44Ydnar88
Post by 44Ydnar88 »
I am just finishing up a couple galley panels, the original woodwork is cherry stained mahogany plywood. Not being too concerned with the grain as I'm adding doors , I used birch. Not the long grain as the mahogany. I got a really close color match using, in this order, minwax red mahogany, one coat, one coat Sherwin williams orangewood , two coats traditional cherry. I did A LOT of samples,and combinations before I got it. Down the line someone had been using teak oil to bring back a little color, I think that's where the orange was throwing me off. Good luck
76 F25 H/T Express
96 Baja 208 Islander
87 Baja 180 islander
Not sure what year your boat is but here is a little info that worked for our 78 f32--- I had to clean up all the worn teak inside etc and read that the original stain used was the same as the Min Wax Red Oak, well it is a dead ringer as I used the red oak on all the panels and it matched perfectly ---- try it on what ever new panels you make if you have that stain in your boat to see if it matches----Happy New Year--- Mike
jordan
Post by jordan »
Try using Cherry wood, just a clear coat on it looks very close to what the teak looks like in your boat.
Jim
SHEGAVEIN (F-32)
Capt. Jim Jordan
lawyerdave71
Post by lawyerdave71 »
mikeandanne wrote: I had to clean up all the worn teak inside etc and read that the original stain used was the same as the Min Wax Red Oak, well it is a dead ringer as I used the red oak on all the panels and it matched perfectly ---- try it on what ever new panels you make if you have that stain in your boat to see if it matches----Happy New Year--- Mike
I am in TOTAL AGREEMENT Min Wax Red Oak is a dead on MATCH!
In fact it was so dead on, I restained all the wood in my cabin!
Captain Dave -
1978 F30 Flybridge Express
8lug
Post by 8lug »
i think i used red oak in the last boat to match up some trim pieces and if i remember correctly it was a dead ringer but in this boat
we are doing something a bit different
we are going to varnish every square inch of wood with cptn's varnish i love the way it looks when you
sand smooth and apply 3 to 6 coats it has a bit of a darker look
i guess the cpt's varnish already has a stain in it
so it may not matter what type of wood i use if it stains it in the process
i got a stick of pine and a stick of oak i can do i little testing on
but probably going with birch for the wood panels
Scorpion07
Post by Scorpion07 »
Add another to the red oak category. Just tried it. Exact.
Although I do miss the honey look.
georgepet
Post by georgepet »
Maybe I'm really wrong, but referring to the F32, wasn't most of the interior wood mahogany??
would love to know for certain because of some work I'm doing this winter.....
cheers
G
George P
1978 Trojan F32 "Defiant"
georgepet wrote:Maybe I'm really wrong, but referring to the F32, wasn't most of the interior wood mahogany??
cheers
G
You may be correct ,I will check my option sheet when we get home----- all I can say for sure is the red oak stain matched the factory original interior panels perfectly---Mike
44Ydnar88
Post by 44Ydnar88 »
I second mikes statement on the mahogany. It 'looks" like teak, the original owner thought it was teak, heck i thought it was teak. But with the panels removed it was pretty obvious on the back unfinished side. Still very attractive finish though,
76 F25 H/T Express
