Wiskey Girls maiden cruise
Posted: Tue Jun 05, 2012 10:01 am
Hey all, I just wanted to pop on here and let everyone know that my girls maiden cruise went very well. I still need to get comfortable with putting her back in the slip.
Anyhoot, I have a few questions for all who may have the answer. First off, she's a Grey Marine Fireball 220 reverse mounted modified American Motors Fury. Original engine.
1. My temp sending unit seems to not work. I don't know if it's the sending unit or the actual guage. When I turn the key on, it does register so I know it has power. However, it never goes up past the lowest point. I'm wondering if one could tell me what sending unit to replace it with. It looks like a standard unit and very easy to get too and one wire fed. Heck, I don't even know if it has a TSTAT in it. I'm planning to put a 140 in it when I go to replace the temp sensor.
2. Second, the single belt drive pully system squeals like all get out when I first start her up. After a few revs, she calms back down and all is quite. However, last time I started here, she wouldn't stop squeeling so I popped the lid and see that the belt is not turning anything. Water pump seems to be free because I can turn it by hand and the same with the alternator. I hope it's just the belt. I'm gonna pull belt off this weekend and see if I can get another one at the local marine shop. No telling when it was replaced so I figure new would be better than just tightening it up.
3. She does seem to steam alot to me when at the higher RMPs. however, cruising at 2200 and 2500, she doesn't steam at all. Also, I've noticed an good amount of oil at the base of the carb from when I ran her up to 3300 RMPs. I'm wondering if that is from worn rings or valve seats allowing accessive blowby through the tubes pointed into the carb. Other than that, she purrs like a kitten and doesn't miss a lick or smoke at all. She has 1149 hours on her. As for the steam, I've read some of the post on here and will be looking into that problem based on what I have read. A new raw water pump is on the to-do list as I didn't worry too much about it since it does push water out at a pretty good flow rate.
Any comments or recommendation will be greatly accepted.
New pics as well:
http://s1222.photobucket.com/albums/dd4 ... %20Marina/
New pics as well:
