F32 New owner and project boat Help and advice.
Posted: Sun Nov 06, 2011 12:26 am
Hello everyone and it's great to see I'm not the only nut who will devote my life and savings to restoring and old classic.
I just bought a 1975 F32. She had minor engine problems and What seemed to be a fairly decent hull with no major damage. I bought it 300 miles from my home and fortuneately the previous owner is a very nice gent and has allowed me to stay in his home to refresh the boat for the trip down to south Florida. Maybe he's sorry for me.
I found that the boat had basically two previous real owners who used and maintained the boat. The second owner kept very good records and this gave me some insight into the boat. He kept good records and did alot of textbook maintenance but really didn't understand boats. He spent alot of money and thank God for that because everything works. But because he did not looking into the structural workings of a boat there is alot of wood rot in the back deck. He didn't realize the boat needs to flow, so all of the areas can dry out. All the drains were pluged with dirt and this allowed water to settle in areas he could not see. So now I've developed a nice project of removing rotted wood and fiberglassing it all back in to get the structual integrety back to the boat so it doesn't buckle on me in heavy seas. I found all this while trying to sort the steering out and realized someone was there before and knew this boat needed serious structual repain. This is the second phase recondioning needed, I believe after my research on these boats. In ~1989 seems like boats of this era needed repowering as mine had with INDAMAR 351 CID (Fords). At that time he should've gotten diesels. Two extra aft tanks and new onboard charger from shore power. And now the structure goes soft. Which I keep finding.... !"£$%^&*$$$$
The Engines seemed to have gone in this model in the late 90's or people got Iacoca fever and got rid of the cryslers. Now the structure gets weak.
I'm currently working on the wood work in the stearn because the stearing went out and I see some rot in one of the stringers. Luckily I have some experience with fixing this because if I had to hire someone to do this work I' sure it would have been in the $3 - 5K range to do what I'm doing. But it seems like some work was done in the past to put in the aft tanks and this may be where some !"£$%^&* didn't do a proper coating to the wood work and the water invasion started.
What I'm looking for now is a complete set of plans to the boat to find out what the structural configeration originally was. I can pretty much repeat what the last guy did with the additional genious of sealing the wood with either fiberglass or paint so that it will last. Does anyone have any pics or plans.
As for my two Indamars, they have great compression and with the exception of a click in the SB motor on the far riser hose, she sounds great. I may need to change the risers and this I would like to do once I know I have two strong motors. The port only shows signs of a weak engine water pump. I will continue with previous owners immaculate oil and fuel filter changes. Cudo's to him for that.
Electrical wireing all there, but hell if I'll ever figure all that out. I would rather insure and wait for the fire to start. Seriously if anyone has some serious wiring advice, please pass it on.
If anyone has any other advice or sugestions or some good ole support, bring it on.
Also after taking all the dead gas out and starting to do the work, she's now starting to smell more like a fishing boat, oil and grease, than an old gas tank. That's motivation enough.
Happy boating and look forward to hearing from some other F32 and Trojan enthusiast.
Island Dr.
Island Dr.
