Posted: Mon May 25, 2009 10:27 am
JWRAPE...your setup looks good....and yes. connecting two batteries in parallel like that with no isolation is an acceptable practice.as long as your chargeing system can handle the double chargeing output.its done all the time in the small diesel pickup world. It is preferred that they be identical in age and type when replaceing but NOT necessary.Charge Leveling occurs between batteries. its perfectly normal...even with batteries that are in series (and under load). I have been to large battery backup sites and I'll tell you this...when one dies or gets weak,they dont change them out all at once. The problem with this setup or any setup utilising more than one cell is what happens when one cell starts to die .To state it as simply as possible,when a cell dies it is most often due to internal shorting . The cell becomes a load rather than a source.
Replacing both at the same time makes it easier to predict when its going to happen. There IS a simple tool that makes the prediction easier. I have
been useing one of these tools for well over 40 years.Its called a hydrometer and its available at Walmarts for less than five bucks.With 30 cells on board, it would be useful to get one and learn how to use it.As a cell dies its specific gravity changes.
disclaimer: Not useable for gel cells or batteries that are actually sealed with non removeable caps nor batteries that have developed a sulfide coating(sat dead for too long).
