10 meter repower
- alexander38
you've not gotten a bigger boat Paul because she who must be lived with wants a bathtub, And you've not found a sportfisher with one yet.
What good is a BATH tub when most hot water heaters aren't large enough to support one? Thats how I got out of a bathtub model for my wife. Told her all she would have is COLD baths!
2011 Trojan Rendevous
Solomons Get Together 2011
Ocean City 2012,2013,2015
========================================prowlersfish wrote:I don't make a enough to buy a boat with a tub . But I have owned boats that could be call tubs
We ran a line for hot water from the wetbar to the lazarette.
Run hot water to the lazarette with bubble bath and circulate it with the livewell pump.
If you can believe this it's a great redneck hot tub.
If you can't, well you would be right.
These Internationals DO HAVE some nice features though.
fastestonehere
chauzer wrote:300 horse... per cylinder? sooo your cranking 1200 horse out and only doing a 7.70 quarter mile? what are your 60 foot times?
4.80 1/8 and 1.1 60ft. 6500 rpm 2 step on trans brake shifting 9500 rpm . 456 gears 32x14.5x15 tires chassis weight 1704 without driver 74 mm turbo on m1 meth. and 12 150 pound fuel injectors no intercooler
stock block 30 over stock head casting oe lash adj. factory stock crank ;
every 10 passes taken apart for inspection
"She's Wide in the rear"
- ready123
Agree... I smiled to myself about the logic of applying dragster theory with engine rebuids after 7 second runs and applying that knowledge to marine use where engine high load is ongoing for hoursprowlersfish wrote:Back to boats
todd brinkerhoff
Holy crow, what topic are we on now
- alexander38
but if you apply it right you can get from green 1 to green 3 real fast....once
- alexander38
And to fill the tub you need a 10 gallon water heater set @ 180 f it doesn't take all the hot water that way, and use engine system to heat it. the puppy's love it.
And one of my 1st boats was a tub it was a 21' Manatee with a 250 Johnson what a pos but it was good for catfishing.
todd brinkerhoff
Not sure where this topic is at this point, but if you want to build a 496, why wouldn't you look at the specs that were created by a marine engine company, ie: crusader or mercruiser, on their 8.1 liters? The 385 hp, 8.1L has some decent reviews for the medium sized boats.
Of course, I'm not sure how this applies to drag racing or bathtubs...
- alexander38
the 8.1's back fitted in boats from what I've seen have some troubles with adding all the controls and sensors and d##@ computers for them. Now without all that and one could use carbs and electronic spark boxes like a thunderbolt 4 system then I could agree, But what will the hull and rudders do at the higher speeds ? Will the platform handle it ? Can it take the stress ?
Ready - I thought the same thing ... 7 seconds x 10 runs = 70 seconds between rebuilds ... wouldn't get you out of the marina.ready123 wrote:Agree... I smiled to myself about the logic of applying dragster theory with engine rebuids after 7 second runs and applying that knowledge to marine use where engine high load is ongoing for hoursprowlersfish wrote:Back to boats
Fastest - we're all busting your chops because you've logged onto the wrong board - might try TheHullTruth.com or ScreamAndFly.com for race boats ...
The fastest Trojan ever probably runs 35-40 knots ...
- alexander38
Naw Ross won't fit in over a tht due to the engines don't hang off the a$$ of the boat and steer from the center.
Do you think he will fit it with a parachute?
