318 no oil pressure
Re: 318 no oil pressure
Glad you got pressure now . As long as the filter not hitting you should be ok . One question you said hose on the remote oil filter ? I don't recall them coming with a remote filter . Some did come with a oil cooler that had hoses . If it had a cooler maybe it or the hoses could be plugged
mpjosh2001
It was an aftermarket set up that a previous owner put on there to make filter change easier. I might put it back on, with the hoses correct this time. Haven't decided yet. It has an oil cooler for the transmission. That is still there. Thanks for all the input.
