yorklyn wrote:I would bet money that all you have is a leak from one of the trim tab mounting screws. all that "bump out" is a piece of hard wood backing for the trim tab screws that is glassed in(using that term loosely since the glass is basically there to just hold the wood and not seal it from the bilge. )
I quit using 5200 a while back. although I disagree with the term "permanent" that 3m uses in the description, it can delaminate fiberglass when force is used during dis assembly of a part glued with 5200. 4200 is usually more the adequate.
If possible i would try simply removing and rebedding the mounting screws for your tabs with 4200.
Your transom (and Hull) are solid glass so the only thing that could rot would be the wood used to back up the screws. i found the i had more then enough thickness in the fiberglass transom for the screws to bite so i would not worry too much about the wood right now.
As far as the strut bolts you should be able to see water weeping from around a bolt if it is leaking. if its not I would try to wait until your cutlass bearing needs replacing, pull the strut, replace the bearing and then reinstall it with new bolts and caulk.
Thanks Todd. That makes total sense. I was wondering what that bump was. I'll haul out and check out the bedding on that trim tab. I like your POV on 5200. Makes sense.
did you end up selling the boat? I get jealous every time i see it!
