International Prop Question
Todd is 100 % correct . You should be able to get in to the max rpm range at WOT . On diesels you should be able to reach rated rpm plus about 100-150 rpm ( mechanical injection) . anything less your over propped and are straining the engines . That goes for gas or diesels
