Project: Trojan 10 Meter Express
Natchamp
Post by Natchamp »
RWS wrote:..........while she is still on the hard it might be a good time and easy too to add drop fins to your trim tabs.
RWS, do you have any pictures of what these are like? If they help with fuel economy I'm all for it.
Natchamp
Post by Natchamp »
jhalb wrote:Mark, I see you replaced the floor steep switch on your head. Do you still have the old one? I could use it if the repair on mine doesn't hold. If you want to sell it let me know.
John,
What "floor steep switch" are you referring to?
John,
I think he meant "floor step switch/valve"
jhalb
Post by jhalb »
I need the old style pedal lever. The rod your foot steps on. My wife flushed the toilet with a cast on her foot and broke off the plastic end. I have it epoxied together but had to re fix already.
John
"PELICAN"
1983 10 Meter Express
yorklyn
Post by yorklyn »
Todd Pote
1987 10 Meter Mid Cabin
Double Pote-N_Sea
jhalb
Post by jhalb »
That's it, with the plastic end on it.
John
"PELICAN"
yorklyn
Post by yorklyn »
The one above is what I have in mine. there is a plastic cover that goes over it. if you go to the seacoast link above they sell both pieces . I think the metal piece is like $58 .
Todd Pote
Double Pote-N_Sea
jhalb
Post by jhalb »
I need the older model with the molded on black end. See marks post on 6/29 , 9:46 am. The third picture down. This looks different than the new model.
John
"PELICAN"
Natchamp
Post by Natchamp »
John,
I don't have any of that, I wasn't too eager to keep them laying around :) The new bottom assembly I bought didn't come with rubber grip either but I'm just going to buy one that fits over the steel rod, easy to come by.
go to google images ant type in this
bennett "drop fins"
numerous pix better than mine.
These are a diredt bolt in replacement.
Same attaching points
same width
but:
longer
PLUS
the drop fins
equals more lift.
Natchamp
Post by Natchamp »
Well,
I’m getting closer and getting the stainless steel top done is a major milestone. I still have to install some front struts for support but it’s pretty much complete and installed. I will start on the canvas work very soon. I also installed all my zincs but that isn't nearly as interesting to show as the top!
Crazy Yankee
Post by Crazy Yankee »
RWS wrote:good move on the crapper Mark.
just replace all the soft parts and you're good to go.
This was important durin my quest for efficiency in getting RWS up to .83 nmpg. ESPECIALLY if you have full tanks and a number of guests/gear.
Keep taking those photos and see about getting a magazine article done. If I were you, I would "shop" it.
While you are in the head I wonder if I can share a problem I have on mine with you that I have been unable to solve.
We seem to be collecting water inside the shower sump.
I can't tell if it's seawater, bilge water or rainwater.
I originally thought for a long time that it was bilgewater when the fuel tanks are empty, collecting at the fwd engine room and seeping into the shower sump beside the sump hose,, but I have since sealed that hose opening on both sides with RTV. I also put a plug in the thru bilge overflow hole.
Just something to consider while you are in your head, as the two are identical. Might help eliminate a similar problem with yours.
KEEP POSTING MORE PICTURES!
RWS.....we have the same problem. I was told it was condensation from the air conditioner, but I'm almost positive when we put in a Mermaid last year we drained that into the forward bilge. I just pumped mine out for the second time this season yesterday.
1985 Trojan International 10 Meter Express
Crazy Yankee Sportfishing
Nice job on the top
Natchamp
Post by Natchamp »
Thanks Paul!
EM63
Post by EM63 »
Good lord - That's awsome again :shock:
I can't see any screws at the setup - really clear.
It looks stable to build up a upper helm :D
BTW: you have dropped the wrong anchor for that ground :roll:
Greetings and success in any progress - Heiner
