Velvet drive info
crazyperkdriver
Re: Velvet drive info
i have a velvet drive with no tags on it a 70 or 71 or 72 how can i tell what the gear ratio is
if looks like the one in the photo above its a 1 to 1 If it looks like the ones on page 1 then it would be a reduction unit
crazyperkdriver
thanks i have a reduction unit
With out the tags it will be hard to tell what ratio it is . It its installed in a running boat then you could use a photo tach to compare engine to shaft speed . If you can tell use what exact model boat and engine , I may be able to what the boat can with . ( no guarantee it was not changed though )
crazyperkdriver
motor and trans have been changed but can i just spin the fly wheel side and mark the prop side and spin to see how many times it turns before the prop makes a full rotation will this work ?????
crazyperkdriver
which will give more top speed a one to one or a reduction style trans ? i have switched the motor to a 400 hp (stroker 383 full roller motor with a mild cam) it had a mercruiser 260 hp (350) in a 26 ft. sport fisher style hull new motor has a ton of low end torque and i would like to b able to go apx 40 + if possible. which trans would be best to use
crazyperkdriver wrote:motor and trans have been changed but can i just spin the fly wheel side and mark the prop side and spin to see how many times it turns before the prop makes a full rotation will this work ?????
No you can't you need to engage the clutches and that takes a min of 400-500 rpm ( need trans oil pressure to engage the clutches
crazyperkdriver
yep have to have clutches engaged tried to check but its like its in neutral thanks for all your help
