87 10 Meter express performance specs.
BobCT
speaking of bottoms......
Post by BobCT »
I have two thru hull transducers that are no longer used. Would you remove and patch the holes in the hull or leave as is?
One has a wood backing which is getting a little soft, the other is an Airmar transducer that is solid. Just wondering if I should leave well enough alone or pull them over the winter.
Bob I would do a new post you may get a better response
