was thinking if this would work?
Bummer.. I can free dive that deep!
Danny Bailey
Post by Danny Bailey »
It will work but the risks covered above are real. I used a small gas generator plugged up with a shore power adapter to make morning coffee in between taking the old onan out and installing the new Northern Lights.
carverman
well that is what i was thinking
Post by carverman »
this little honda 2000 you can't even here run i had the guy at the store run it outside for me and wow it was nice .. all of you have great things to say and look for .i have got those those two things you all said to get the co det.. and gas .. my yacht has them and they work however i was going to just maybe try this little gen out on the back and see if i like it ? if any of you think of any other reason not to please let me know
other then portable gensets don't belong on a boat I can't think of a thing
Re: well that is what i was thinking
carverman wrote:this little honda 2000 you can't even here run i had the guy at the store run it outside for me and wow it was nice
With no load? Yes it should be pretty quiet at no load... get it up near 2000 W for a long time and you will be aware of it.
As I have suggested before if for longer running time try to get it on shore. I have also seen them set off in the dinghy.
Common sense when placed on the swim platform should be no problem. i.e. be swinging at anchor so that the bow tends to face into the wind.
CO fears are somewhat exaggerated unless it is brought inboard.... a CO detector in the living space will give you all the comfort you need.
Once you find that your lifestyle afloat changes where you are using it a lot and thinking about moving up to the Honda 3000 then I would put a 3.0Kw Westerbeke, which is pretty small, as a fixed installation.
http://www.westerbeke.com/Products/prod ... aspx?id=36
g36
Post by g36 »
i know this will work because i have a honda 2000i. i use this camping and when power goes off at the house did this to recharge my batteries last year when anchored out for july 4th. generator needed an impeller and wasnt able to get one before we went out. make up a pigtail for the gen to the shorepower cord on the boat, easy. tied my unit on my swim platform on f32 runs fine back there. co alarms never regeisterd anything. the honda has overload protection that will kick in if you try to overload it.
1997 CARVER 405
"the BLACK PEARL"
past fleet
1978 F32 SEDAN CHRYSLER 318's
current fleet
1997 seadoo gts
1997 yamaha wave venture
1985 sunbird 18 ft runabout
1968 coronado sailboat 25 ft
sunfish
14' hobie cat
canoe
8ft portabote
foofer b
Post by foofer b »
My brother runs one to power his whole boat, a 24 Glastron express cruiser. Cannot run a/c and microwave at same time but everything else. Puts it on swim platform.
MY CURRENT FLEET
2003 KEY WEST 2020 WA
1978 14' ASHCRAFT SKIFF
