TROJAN F 25 (PROP)
MattSC
Post by MattSC »
I have a Michigan Wheel 14 x 10"Nibral Dyna-jet with a full cup. I currently have a 330HP Crusader which replaced my old LM318. After trying several props, I ended up with the same one I ran with my 318, though opposite rotation. I'm still running a Borg Warner Velvet Drive 1:1
You would think I would be running more pitch, but the two engines have different power bands with the new engine having to reach between 4800-5200rpm compared to the 4000rpm with the 318. I cruise the same speed/rpm I did before 15-17kts depending on conditions around 2900rpm. The speed difference comes between 4000-5100rpm which I only try when making sure I'm within specs for the engine. It does jump out of the hole pretty quick and is much better on fuel.
Make sure you keep your trim tabs all the way up in a following sea, that should help.
foofer b
Post by foofer b »
My F 26 will give you a workout at the wheel in a following sea.
MY CURRENT FLEET
2003 KEY WEST 2020 WA
1978 14' ASHCRAFT SKIFF
Like Matt stated, tabs up in a following sea but also "shovel the coal to it". In other words give it enough throttle to keep it moving faster than the following seas and it'l handle much better.
MTP
Post by MTP »
Paul wrote:Like Matt stated, tabs up in a following sea but also "shovel the coal to it". In other words give it enough throttle to keep it moving faster than the following seas and it'l handle much better.
I am sure that applies to an F32 as well
TIKI III
1985 F32
270 Crusaders
Wet and happy
braymond
Post by braymond »
Thanks, I'll definitely try raising the tabs. I have them set flush with the bottom and usually don't need to mess with them, so I don't, but I give that a try.
I have learned that "shoveling the coal to it" helps a lot, but I'm only seeing about 14knots at 3000rpms and that already burns about 10-11gph. It rides great at about 3300rpms and about 18knots but now I'm burning over 15gph. I'm only getting about 3800rpm max, but I think that's a carb problem.
I just had the carb rebuilt this week. It was really a mess. I should have taken a picture of it - hard to believe it was running. I am hoping that it will run and little better and burn a bit less once I get it back on. This weekend is looking good for a test run.
1973 Trojan F25 - CC
Chrysler 318 - stock
cclark75006
Post by cclark75006 »
Well be went out and ran the boat this past Saturday. (After full tune up)
We were full of fuel (60 gallons) and had a full load of water (30 gallons)
plus 4 big people, so I estimate our weight was as follows:
Boat 5450
Fuel 375
Water 250
People 1000 and gear
Total 7075 pounds
Here is what the GPS recorded:
2000 rpms= 9/10 mph
2500 rpms= 13/14 mph
3000 rpms= 16 mph (this is top rpm @ full throttle)
I think my engine is a bit tired, but it's running smooth and starts easy. (Merc/ford 351) Still dont know for sure if it has the 14 x 10 prop so I will just check it next time I have her out of the water. Bottom is freshly painted and clean.
Curtis
Curtis , are you sure the bottom is clean ? maybe the the carb is not opening fully ?your top rpm should be a lot higher
cclark75006
The bottom is clean for sure, just painted a couple of months ago, on a trailer until three weeks ago. I will investigate the carb to see if it is fully opening. Thanks The engine is original, burning/leaking one quart oil in the last 15 hours of operating!
braymond
Post by braymond »
I agree with PF. You should be seeing at least 4000rpms at WOT.
Ditto on checking the throttle linkage to the carb first. After that, do a compression and leakdown check. You can get a tester cheap or even borrow one from autozone. It's a fairly easy DIY project.
Yes Sir, it does ... tabs up, throttles down.
cthattars
Post by cthattars »
i own a 1976 f26 i use to get 17 to 18 top untill i found that the tune up they put the right plug in according to ngk but im a mopar guy and the 318 that was in the boat needed 3/4 inch reach plugs and ngk was only 3/8 inch reach the plug was firing in the cylinder head not the cylinder it self now top end is 28 gps at 3500 rpm 14X10 prop slight cup
60 gallons of fuel and water with 4 people and gear this has a full wrap windsheild and hardtop
You should be closer to 4000 rpm ( clean bottom) maybe remove the cup or a little pitch
BTW I find champion the best plug for a mopar , stay away from NGK unless you have a Japanese car .
cthattars
mopar power
Post by cthattars »
champion plugs is what im using the same i use my 67 cuda and 73 duster both run 340's and 4 speeds, 318 in my boat you cant hurt that engine since im here in the great lakes lake erie im taking off the bottom paint and putting on epoxy two part paint that should give me alittle more speed so i'll reprop it later for lower rpms and or more speed
kjpf25
Re: TROJAN F 25 (PROP)
Post by kjpf25 »
Just bought a '79 F-25 but have not had it over 2000 and not sure how to tell mph/knots.
Paul - SW Ontario
Post by Paul - SW Ontario »
F25, Chrysler 318, 225 hp, 1:1 velvet direct drive, 14RH10 with cup....Approx. 7200lbs usually.
Brand new bottom....2 part polyurethane
On plane - 14 mph @ 2200 rpm
Cruise - 19 mph @ 2600 rpm
On it - 23 mph @ 3500 rpm
WOT - 27 mph @ 4200 rpm
The bottom made all the difference!!!!!!!
1973 Trojan F25.5 - SW, ON.
2012 Triple Axle trailer
1978 C&C Mega 30' Sailboat
2014 Triple Axle trailer
2016 Highfield CL290 BL RIB
2017 20hp Suzuki 4 stroke
