Update...
Had a leak down test done today, motor and all Cylinders Test at 14 % leakage which is an acceptable limit..
Thanks for all the help....
Hope fully should close on this on Monday....
Oil analysis Expierence
AaronThompson
Engine Oil Analysis
The Correct links form above are:ready123 wrote:Sodium & potassium suggests coolant leaking into oil.... which your results also show as being present.
Copper and lead suggest bearing wear which would not be a surprise with coolant leaking into oil.
Sounds like the bottom end should have been done when the top end was done...
Go to this site for more info http://www.annapolismarinesurveys.com/u ... es.htm#Oil
here is a pdf of where the metals might have come from:
http://www.annapolismarinesurveys.com/u ... alysis.pdf
http://www.annapolismarinesurveys.com/oil-analysis/
http://www.annapolismarinesurveys.com/p ... alysis.pdf
Thanks!
- alexander38
SPAM
Jerry
You had elevated bearing materials in your oil.... A leak down test does not tell you anything at all about that.cuppa wrote:Update...
This is a old post brought back , by now he has walked a way or been cruising a round happy or worst case repoweing as we speak .
I see he did by it and was having fuel system issues in august. No talk abour engine issues
