May 2017 Upper Bay Rendezvuex
Posted: Fri Dec 09, 2016 11:57 am
by Doc Holiday
Hello Everyone!
It's been a busy autumn yanking out the stbd 6-71 for its rebuild but she should be ready to go by mid-spring.
6-71 Engine Removal .png (107.84 KiB) Viewed 5261 times
671 Eng Removal (22).JPG (201.78 KiB) Viewed 5261 times
671 Eng Removal (24).JPG (201.27 KiB) Viewed 5261 times
I'm probably doing a shake-down cruise to Higgins in St. Michaels the beginning of May and going to Henderson's Wharf in Fells Point towards the end of May. John Leed will be in tow both trips as the tech advisor. I'll update this post as the dates firm but thought I'd send out some tentative plans for the start of the 2017 season.
Re: May 2017 Upper Bay Rendezvuex
Posted: Fri Dec 09, 2016 12:13 pm
I met John Leed at Higgins in 2009 . He came down for the rendezvous . Good luck with the project
Posted: Fri Dec 09, 2016 5:41 pm
by Doc Holiday
Thanks prowlersfish! John said that the Trojan design team took great pride in making sure engine swaps could be accommodated without cutting fiberglass.
671 Eng Removal (2)-1.jpg (187.06 KiB) Viewed 5249 times
I jokingly asked him if that meant sometimes lifting the engine vertically... A serious "Yes" was the reply.
6-71 Removal 4.jpg (134.41 KiB) Viewed 5249 times
Think I'll wait to bolt on the turbo until after the block is back in place!
Posted: Fri Dec 09, 2016 6:38 pm
I had to take my door off but the Cummins came right out of F36 , I could removed the stop and opened more but the screws would not budge.
You should try and get a 671 out of a Viking 45 . Not fun
Posted: Fri Dec 09, 2016 9:00 pm
I forgot to ask what Yard are you at ?
Posted: Fri Dec 09, 2016 9:13 pm
by Doc Holiday
Bay Boat Works on the North East River. Great people there.
Posted: Sat Dec 10, 2016 9:13 am
It looked familiar , but I can't recall going there . But I believe I when to Jackson a few years back (by land) so its possible .
Posted: Sat Dec 10, 2016 4:56 pm
by WayWeGo
If you are suggesting a get together in St. Michaels or Baltimore, we are interested. The only caveat would be our older daughter is graduating the weekend of the 13th, so that would be out for us.
