'69 Chrysler 383 Coolers
oldwood69
Post by oldwood69 »
Need a little help from the crew here. I would like to replace the engine oil and transmission oil coolers on my motors. I have had trouble with them in the past and it is time for some new parts when it comes to reliability. Here is my problem, I can't remember the dimensions!!! These are on a 1969 SeaVoyager with twin Chrysler 383's. I am positive that they are 2" in diameter, and I believe that the engine oil cooler is a 6" coil (the cooling part, actual length probably 8-9") with 3/4 threaded fittings and 3/4 hose fittings. If my foggy memory is correct, the transmission cooler is the same diameter and fittings, but is a 9" coil (probably 10-11" overall length). Does this sound right??? I found a place (Palmer Power in Houston) that can have the coolers made to whatever dimensions and fittings I want, I just want to make sure that I order them correct as they are custom built and not returnable. Or, does anyone know of or have recommendations to get them somewhere else? Thanks!
69 Trojan 36' SeaVoyager
Re: '69 Chrysler 383 Coolers
My father's old '69 also had a 383, but it's been gone for 15 years. Big D may be able to help you with dimensions etc. I know it's a far way to order from, but Anthony Keats Marine http://www.anthonykeatsmarine.com/ is an old school Chrysler dealer and may be able to provide proper replacement parts. Yes, it's a long way to order and ship from, but with the exchange on the dollar you may save 20% off the top!
You can try Beacon marine too
oldwood69
Post by oldwood69 »
I sent an email to Anthony-Keats last night and they were quick to reply this morning. Price is comparable to what I found at Palmer, but timing was a little longer. Duh, on the contacting Beacon! That should have been my first try...will get in touch with him now. Thanks for the help!
