Check your bolts and gasket on exhaust manifolds
Posted: Mon May 20, 2013 3:58 pm
by gordd
At start up did have a small leak at port side exhaust manifold above impeller/water pump . gasket was cracked but plate was so corroded was leaking when went to take it of it just snapped. I chalk it up for fun of having old boat. Glad caught it on dry land though and not on water somewhere
exhaust manifold plates rusted
Gasket trouble.jpg (211.23 KiB) Viewed 6179 times
Bolts were rusted in the holes . Still have cpl broken ones to take out . Lots of wd40 and let it soak
Starboard side wasnt leaking but decided to change it after seeing shape the other one is in .
