prop shaft removal
Posted: Sun Aug 12, 2012 12:52 pm
I was wondering how to or how difficult it is to remove the prop shaft. I have a 1978 F26, crusader 350 engine with B/W velvet drive direct or straight drive transmission. I have discovered that the engine alignment may not be perfect and I plan on replacing cutless bearing and checking or adjusting engine alignment. Seems the cutless bearing is wearing uneven. Where the prop shaft enters the cutless bearing I have excess wear on the bottom portion of bearing. Where shaft exits / aft end there is excess or more wear on the top area of cutless bearing. Is taking the prop shaft out as simple as just disconnecting the coupler joining shaft to transmission?? Boat is out of the water on blocks now.
