Bottom blasted
Paul - SW Ontario
Bottom blasted
Post by Paul - SW Ontario »
Just had the bottom soda blasted...it was a tough go to say the least - the 39 year old blue bottom paint was a challenge for these guys. Four hours, start to finish...
Gelcoat condition: as inticipated...entire surface cracked, near all the same....a few spots where factory gelcoat had air pockets. Absolutely no wet spots or blistering.
Cost for blasting $900 plus our HST (13%) = $1017
Big job ahead of me now...skim coat the entire bottom with 2 part Watertite epoxy - bring the gel coat back to smooth again, sand, prime, sand, then paint (white high gloss 2 part finish).
Using all Interlux products $429 worth...should be enough with a bit left over.
Had enough of ablative antifouling paints over the years, going to try to wax the heck out of the bottom as others here in L. Erie are doing with success.
1973 Trojan F25.5 - SW, ON.
2012 Triple Axle trailer
1978 C&C Mega 30' Sailboat
2014 Triple Axle trailer
2016 Highfield CL290 BL RIB
2017 20hp Suzuki 4 stroke
Commissionpoint
Post by Commissionpoint »
Lots of folks here run with no bottom paint. About the worst part of it is the algae that will build up on the white bottom. Most folks spray on some Slimy Grimy or similar at the end of the season and it just falls off with the spray from a hose.
It took them four hours to do mine as well $800 down here. Gonna spray on a t.wo barrier coats before anti foul.
Mine came out pretty white with exception where someone had sanded through gel coat so will use the barrier coats
Paul, here's some food for thought from a previous thread.
http://www.trojanboatsforum.net/wforum/viewt ... sc&start=0
I know exactly what you're talking about with all the hairline cracking throughout the bottom. I've looked into this and keep coming up with the same suspect; too much gel. Fix it right now, so you don't have it coming back to haunt you later.
