anti siphon valve
anti siphon valve
I am installing new aluminum fuel tanks and the subject of anti siphon valve came up. The original had shutoff valves at the tank and right before the fuel pumpl.
I think and correct me if I am wrong, an anti-siphon valve is supposed to block the flow fuel in case of a line break lower than the tank. As the fuel pump draws fuel from the tank how does a valve know the difference from a leak?
your right Larry it's a must have for a gasser :wink:
koviak
Post by koviak »
Larry, your fuel pump is drawing thru valve with vacuum so the small spring and ball release to flow. If a line leaks without vacuum the valve will not open.
Dennis
1989 10 Meter Mid-Cabin
koviak wrote:Larry, your fuel pump is drawing thru valve with vacuum so the small spring and ball release to flow. If a line leaks without vacuum the valve will not open.
sorry was still 1/2 a sleep... :wink: Koviak is right on the money.. :D
A leak wont have enough "pull" to open the valve . But you still should have cut off valve just in case .
Having a cutoff valve as well seems to be a good plan. My boat has copper fuel lines which I intend to retain. Presently the fuel exited the old galvanized tank via a cutoff valve and flared fitting on the copper line.
Seems like the only antisiphon valves I see are made with hose barbs for hoses. Is there one with threaded connection? I cannot locate one.
g36
Post by g36 »
larry i replaced my tanks this year also and i did replace my antisiphon inline valves at the same time. i also reused my copper fuel lines but did install new antisiphons. if you will pm me i will be happy to give you the info on where i purchased them. these are the correct ones and not the barbed.
1997 CARVER 405
"the BLACK PEARL"
past fleet
1978 F32 SEDAN CHRYSLER 318's
current fleet
1997 seadoo gts
1997 yamaha wave venture
1985 sunbird 18 ft runabout
1968 coronado sailboat 25 ft
sunfish
14' hobie cat
canoe
8ft portabote
